1990 25HP electrical puzzler
Mr. Coffey
Clean filtered fuel. Engine revving under load at approx 2-revs per second. Able to determine that upper cylinder was not sparking. Started with a new coil for each cylinder. No change. Then detemined that by swapping spark plug wires and power pack ignition wires to the other cylinder, the failure moved to the other cylinder. That pointed to the power pack. Installed new power pack with no improvement. Any ideas what's next? Thanks!
Cofe
Re: 1990 25HP electrical puzzler
That is a puzzler:confused:
I wonder if the new power pack is bad?
And another thought to check the coil insulators on mounting bolts.
234rick
Its probably a used power pack with the same problem as the first one.
Mr. Coffey
Thanks for the suggestion about the coil bolt insulators. I'll check that. Power pack is new - bought it from an Evinrude dealer.
jimdd810
also do a compression test
Mr. Coffey
At your suggestion, I checked the coil bolts and insulating washers. In this case, the coils have to be grounded to the block, evidently. I took out the washers, the coils are grounded now, and the problem is solved!
Thanks for your help.
PS. Did a compression test early on - checks out OK.
