wrench 3
- Joined
- Aug 12, 2012
- 2,108
If you get what's left of the bolts red hot or close to it and then let them cool completely, they should pretty well turn out with your fingers.
The cranks should be the same but I'd be more inclined to do a compression test on the other engine, pull the pan and make sure that none of the crank bearings have been hot, and if all's OK use the hole engine.
I don't believe that they use the dowel in flywheel any more. It was only for assembly purposes anyway.
