1990 4.3 wiring diagram
dwayne80
Changed motors due to a cracked block, same engine but don't know where a single wire goes, if someone knows where a 4.3 wiring diagram would be, be much help. The color of the wire is solid light blue, it's joined in a sleeve with a white wire with a blue stripe on it, that's connected to the back of the distributor. Boat will not fire. thx for any help.
Bt Doctur
Re: 1990 4.3 wiring diagram
engine serial number for the correct manual,, type of ignition and fuel system
dwayne80
Engine serial number is 0c775123, thunderbolt IV ignition, quadrajet 4bbl, 1990 Glascon LX
Bt Doctur
Can find those exact colors in this manual. http://www.boatfix.com/merc/Servmanl/18/18E4R2.PDF
Not used for TBIV base timing mode.purple /white and tan/blue are not used in this manual. Only one I have available
Do you have 12V at the + side of the coil?
shift interupt (alpha )
bad/shorted tach (grey wire)
Butch1965
looking for wiring diagram for a 1990 Bayliner capri 3.0...any1 help plz?
Don S
In the future Butch, start a new thread of your own, don't hijack someone elses thread for your question.
