1990 40 hp Johnson bottom end question
karlow1
My bottom end seems to be leaking oil mixed with water. It looks like coffee. It's leaking from the rear of the lower unit when its tilted up. I ordered all of the seals fro the bottom end. (ETS the 11/25). The current problem is I can not remove it. I have removed four bolts, the trim tab, and the upper cowling. There is one bolt under the trim tab. I have not been able to get that one out.
Is that why this thing has not moved. It's boat number 68 on the the I shop chart http://www.ishopmarine.com/ishop/js...&isForSupStore=false&cCatFilter=&eCatSupFldr=
Is that the problem, it says it's a short bolt.
KP
oldrudedude
Re: 1990 40 hp Johnson bottom end question
Yes, the bolt under the trim tab has to come out before the LU will drop.
karlow1
Thanks go figer.
