Last Year I had carb problems, no high speed until I pushed the prime button, so I pulled them apart and cleaned the jets and all ports with spray carb cleaner. When I went out to run it, it was a little better at first but still couldn't get it to plane out. As I was going back to the launch, all of a sudden it just took off. Good speed and everything, so I figured the cleaning dislodged something and it finely opened up. I thought is was running fine until I went to pull my kid on a tube with it. It would usually snap them right up, but now it acts like it did before I cleaned the carbs, no power, and will not get up to speed. Without pulling anyone it seems to be running good. What do you guys think? I didn't put a carb kit in there because the parts shop said I was wasting my money. Should I pull the carbs apart and soak them then spray them out? I don't even know if it was the carbs the way it was doggy right after I cleaned them and then all of a sudden it took off. Any suggestions would be appreciated.
Thanks
Thanks
