sambrigman
- Joined
- Jan 29, 2010
- 212
is there a way to check the stator not running? thanks guys
motor was running fine, shut it off, then will not start, no fire at allYou can take ohm readings on the ignition charge coils.-----Battery charging coils.-----And the sensor coils.----All found under the flywheel.-----If the powerpack is under the flywheel you may have to remove flywheel to test them.-----So what is your motor doing / not doing ?
what would be first suspect?motor was running fine, shut it off, then will not start, no fire at all
