Starboard is always hotter in my case by a good 20*I will bet the Highest Temps alternate between the Port and Starboard sides of the intake. Engines often do that instead of Being uniform and even temps.
I did replace it with the newer 160. So I should plug the T stat housing hole and put it in the intake?Unless the thermostat was made incorrectly from the factory the senders should be separated from direct in coming cold water. Should be on the motor side
Being in Erie just put a 160* in it, won't hurt even if you were in warmer waters
A 160 is too hot for a Raw Water Cooling System. Usable in a Closed System, but a 180 would be used thereUnless the thermostat was made incorrectly from the factory the senders should be separated from direct in coming cold water. Should be on the motor side
Could try that but I don't see how that will help. As before the thermostat housing should keep the water closed inside the block until it opens.Im wondering if I should pull the risers and see if I got all 4 slots open like the merc bullitin. If I do that Im half temped to go back to the restricted.. Keep it at 900-1000 rpms, zero issues
