Problems once again with the Motor.<br />Last week no problems, this week a nightmare.<br />Started motor as usual, problems idling, then on take off could only go 1/4 throttle. Bogged out.<br />With cowling off, manual operation of throttle revs up no problem. As soon as it goes in gear the engine will not go past 1/4 speed.<br />Inspected fuel sytem, hoses, filters, bulb, and carb, no water or trash. Intalled new stator and power pack during the winter. Plugs and wires excellent,. Boat ran great for last 2- months except for shifting into foward gear, adjusted last night in the barrell and remedied the problem. Did notice some bucking during neutral idle, but went away after warm up.<br />Put old power pack back on to see if this was it, engine turned with no start. Engine ran with newer power pack on, but only at 1/4 throttle.<br />Local guy is going to put newer power pack back on and dis
mantle the carb this next week.<br />Chasing ghoasts again and looking for help.<br />Maybe a coil going bad...who knows at this point.<br />Thanks for any help....<br /><br />peteypug..<br /><br />formerly known as jasperastro...
