oldgradywhite
Thread starter- Joined
- Sep 7, 2007
- 232
I have a 1990 50hp johnson with a running problem. I rebuilt the carbs and it was still running poor it has to be at high idle to run at all. when I was running it I pulled the top plug off and it ran the same is with it on. so I pulled the bottem plug and it died. It is not firing on the top cylinder. well only once in a while with a misfire. I checked the resistance the top coil was at 4.2 the bottem 3.5 meter set on resisatance x10. Is there something beside the coil that can cause a misfire on cylinder one? I know my motor has S.L.O.W but I don't know how that works? could it be a stator? My clymer manual isn't very helpful? Is there other tests? thanks
