gatorman21218
Thread starter- Joined
- Jan 13, 2008
- 15
hello. I have a 1990 5hp 2stroke that I am trying to get going. 2 summers ago it spent a little time under water (Hurricane Isabel? lifted the dock box off the dock and it sank. the motor was in the box) any way the marina owner took care of it and last summer i tried to get it going but the piston had froze. i got it moving but it didnt run right. It sat in the garage untill last week I worked on it. I took apart the carb and cleaned it out. the needle looked okay, but the jets started to strip when i tried to unscrew them so i just left them alone. i also changed the spark plug, impeller, and gear oil. This weekend I took it out for a 20 min trip (avon inflatable) and it ran fine on all levels of throtle. I went in for lunch and came back and had it going full throttle on a plane when it started to miss. i throttle back and it seemed to work and i had it wide open again and it just turned off like a light switch. It then was very difficult to start and would stall on idle. I limped back home, not going more than 25% or else it would start to miss badly. at the dock i couldnt even get it to idle before it would stall. the fuel is 2 days old. should i rebuild the carb? I'm at the end of my mechanical experitice. thanks, Jim
