I disassembled, cleaned, and put new gaskets on my carbs this week for the 2nd time in two seasons (last year I also replaced the idle needles). Anyways, I noticed a couple things and have two questions.
1) Last year I replaced the fuel lines on the carbs themselves however they appear to leak a little. I had used marine grade fuel line that I had purchased at west marine that was the same diameter as what was on there previously. Can anyone confirm what the diameter of the fuel lines on the carbs should be and whether there is a specific kind of fuel line I need to be using (manuals and ********** don't appear to indicate this).
2) The choke plate on the top carb has trouble fully opening (~90% open) and I realized that the return spring on the top carb is smaller than those on the center and bottom carbs. The return springs on the center and bottom carbs are the same as the ones on the throttle cam on the other side. So the obvious answer is someone replaced the top return spring at some point with the wrong size spring, but in the carb rebuild kit that I got last year there were two sizes of springs
So now I'm not sure if they give you both sizes either to 1) cover all bases, or 2) the center/bottom carbs need smaller springs, or 3) if the carb kit was put together wrong. I have all the springs, just need to know which one(s) I should be replacing.
Thanks in advance!
Thanks in advance!
