1990 90HP Force stopped shifting
sdxp787
My motor left us floating in the water today. It won't shift. I tried to shift it by the rod coming out of the lower unit and it won't move. Not sure what is going on. I see there are virtually no parts available for these lower units. What do you do when this happens?
jerryjerry05
Re: 1990 90HP Force stopped shifting
Gotta figure if it's the shift rod or the gear.
Did you remove anything from the lower?Screws or pins??
Motor off,needle nose pliers.Remove the TINY cotter key and remove the pin.
Unhook the shift barrel.
REach in and pull up on the shift rod,turn prop both ways.
Then push down on the shaft and turn prop. Lock in gear?
If no gears then the shift rod might have come loose.
If there is gear.Then follow the linkage to the top.
Under the front of the motor,there is a shift mechanism.It could have come loose.Look in and see if any loose or missing nuts.
