kingfish62
- Joined
- Jun 6, 2007
- 42
My 1990 merch 90 horse has an issue that is baffling to say the least. Hope some of you have some ideas! On occassion the boat will stall completely during high speed turns or crossing a wake at high speed. When this event occurs the engine fails to restart due to a lack of fuel in the line. The bulb is empty and requires pumping to bring fuel pressure back to the system. The cabs are clean and seem to function properly. The fuel pump seems to be functioning properly as it will pull fuel back to the system if the engine is started using starter fluid vice pumping the bulb. The fuel/water seperator can is new. Any help in issolating this Gremlin would greatly be appreciated !!
