Need some advice on Johnson 90 90. ser. R 08530852 Lower starboard cylinder only has 85 compression. The rest were 114-116. Did not do a decarb before we pulled the head last night. I wasn't aware it could help. There is some carbon in the ports in the cylinder but the walls look good to me but I am not very experienced with boat motors. What should I look for? I couldn't see any obvious leaks in the head gasket. What's my next step? Is there a way to pull the carbs n take off the rod bearing cap from the other side and pull that one piston? I was thinking of just puttin new rings on it. Any help appreciated. PS I did compression with good batt, throttle open, and all plugs out.
