jwoodall912
Thread starter- Joined
- Sep 7, 2019
- 6
1990 Alpha One - New out drive and shift cable
Had the new out drive and shift cable installed by a shop. It shifted fine for the first 30-or-so hours then started having issues. The drive will shift into reverse and forward just fine. Both forward and reverse will not come out of gear and go back into neutral. The shift cut-out switch starts moving in either direction when coming back in to neutral. I took zip ties and eliminated the cut-out switch by locking it into place so that it will not move. To get the drive in neutral, I have to put pressure on the shifter in either direction and force it back into neutral (by pushing it from forward into reverse and by pushing it from reverse into forward. I went through and re adjusted everything according to the books and other online forums. Any ideas?
