Jeremy90bay
Thread starter- Joined
- Jun 3, 2009
- 277
OK guys, I jumped in knee deep today. I will start from the top.
You might remember my post about the soft spot on the floor. I pulled the carpet out completely and the whole floor was soaking wet. I started by cutting a 6"x6" hole in the middle around where the bad spot was. what i found was about 3" of water that never drain out of the boat. I tilted the boat way up and got it to drain. I proceeded to cut farther and farther back toward the stern it was all bad. My stringers look OK from in side the holes but I haven't takes the whole floor out yet. I have a few questions before I keep going, so here I go.
What is the best way to cut the fiberglass around all the seams where it was put together. for example the seat boxes and where the floor meets the hull.
is it possible that the stringers are OK under the fiberglass or should I replace them anyway?
and last but not least, do I have to pull the cap to replace the transom if I find that it needs to be done.
The more I get into it I'm not sure it is worth it.
Thanks in advance for all your help and advise.
Jeremy.
Jeremy.
