'1990 Bayliner Capri 2050 BR - Deck, stringers, transom, custom interior'
Status
Not open for further replies.
lowkee
Re: '1990 Bayliner Capri 2050 BR - Deck, stringers, transom, custom interior'
Okay, okay, you guys all pressured me into a (mostly nowhere) update! Seriously, though, thanks for the kudos and encouragement.
I took a bit of time off after getting back from vacation simply because my arms were still tired from sanding and 'the fear' was back in me from painting hassles.
Since then, I have dismantled a couple of computer cases I have at home in order to gain some painting practice on items smaller than a 20 foot hull. I also am using a couple of glass shelves for practice, as I can use a razor to scrape the paint off after a session, which comes in really handy for total mess-ups.
To keep everyone up to date with my thinking, I am back to wanting to spray the paint onto the hull using my HVLP gun. I have run into more than my fair share of snags, including paint which never seems to harden (Pettit One-part topside paint.. sucks), and clear coat which causes the Pettit to curdle when applied (UPDATE: It was the acetone used to thin the clear coat which caused the curdling, not the clear coat itself).
So, here is what I am doing to fix these annoying and super-huge time consuming issues. I am scrapping the Pettit topside paint and going with automotive base-coat/clear-coat hull painting. I have two-part base coat on order and plan to use the Pettit remainder (~3 quarts) to paint the inside of the hull and the deck. Then if it goes bad, who really cares, I can just slop a new coat on and orange peel won't be an issue, since it'll have grit mixed in anyhow (for the deck, at least).
In the mean time, I have been spraying the computer cases and the glass shelving with the Pettit in various ways, more air, less air, more paint, thinner paint, wider stream, with acetone, with mineral spirits, then letting it dry, checking for orange peel, uneven spots, too thin, too thick, gritty, or any kind of bad spray (which has been pretty much all of my attempts so far) and trying to adjust my technique to fix the problem.
I plan to do this until I have fully learned how to use an HVLP gun and apply paint without causing myself tons of unneeded sanding time. Will this take a month? Maybe, but at least I'll not be wasting any more paint sand paper and, most importantly, effort! I will have a pearl paint job if I have to become a paint technician at an auto store in order to do it! I am set in my ways and will not stop until I get it right. After all, my truck, lawn tractor and motorcycle could use a paint job, too. I certainly don't want to repeat this nightmare which each of those.
Does that count as a decent update ;)
I'll post some of my paint practice photos tonight or tomorrow, including some pearl examples, although capturing the pearl effects on camera seems a challenge.
So far, for those who also wish to learn to use HVLP guns and to spray paint in general, here are some things I have learned so far (I will update this as I learn more/different):
- Mineral spirits (thinner) tends to evaporate very slowly, leading to runs and sags
- Acetone (thinner) evaporates very quickly, causing orange peel (one of many causes of orange peel) as the paint does not have enough time to self level before the acetone flashes off
- Acetone will cause just about any enamel to curdle within the 1st 30 days of curing
- Two-part clear coat goes on very thin, so 2-3 coats should be expected prior to doing any sanding.
- Automotive paint ($41/gal) is way cheaper than marine paint ($100/gal).
- Two part paint (with hardener/activator) is more time critical (two hours to cure), but in no way, shape or form should you use one part paint, unless you have at least a month or more to wait for it to cure, and up to 4 months for a full cure.
- Two part paint curing time can be altered by varying the reducer type. They make fast, medium and slow reducer, which varies the spray-able time to roughly 15min, 45min, 2hrs respectively. Temp and humidity also impact these times, so plan accordingly.
- HVLP guns aren't as easy to use properly as they look.
- Spraying paint means the paint needs to be almost as thin as water. If it looks soupy it is likely too thick for your spray gun (with a standard 1.4mm tip)
- Orange peel can be caused by: paint too thick, gun too close, too much air, not enough air and too much paint. Any of those factors can be a contributing or only cause.
- ALWAYS do a complete paint job on a test panel prior to beginning the real job. Stripping a test panel 2-3 times is easy; Stripping and re-sanding your project 2-3 times.. not so easy.
- Enamel is meant to be baked, which is why it doesn't self-level very well and takes so long to cure.
- The most important thing I learned about paint and painting.. Enamel cannot be sanded, so don't jump in thinking you can just sand down the orange peel or paint sags, you can't with enamel paint. Use urethane if you plan to sand the final coat.
lowkee
Well, I've been lazy the past few days, catching up on some computer games instead of working on the boat like I should. Although I have made progress since the last update.
I wet sanded the starboard side of the hull completely by hand and have to say, even by hand it is way faster to hand wet sand than it is to power dry sand! Now, I've never wet sanded in my life, so this is totally new to me and I can't be more impressed. I literally sanded one side of a 20 foot hull with one single 2"x6" piece of 320grit sandpaper. Dry sanding this same side used at least 3 sanding pads and 5-6 strips of paper, so that is a major material savings.
So what is bad about wet sanding (everything has a price)? The mess! You get paint dust, now liquefied, all over your pants, shoes and arms, so wear something you don't mind becoming 'painting clothes'. A very important lesson I learned while wet sanding is to wash off what you sand, quickly, as when it dries it is almost like a new paint job, a real drippy, messy paint job, and requires sanding to get off (which means re-sanding everything you just sanded). So wash what you just sanded often to avoid repeating your work.
Of course, the sanding was all for a purpose.. paint! Paint which I got in last night. It is automotive paint this time around, as I have grown to despise topside paint, and since I have to clear coat it, I might as well base coat it, too. Before I submit my boat to the sprayer, though, I still have more practice time to do with my HVLP gun. I'm having a tough time getting paint to spray on without sagging or getting more-than-I-want orange peel, so I'll be spraying on some practice panels until I get the hang of it enough to try the boat again. A major delay in forward movement, but I've been wanting to learn to spray paint for a long time anyway, and this is a perfect occasion to hone my skills.
And the long awaited photos..
Time to find those last few nick and scrapes using my trusty guide coat, AKA vandalism. I can't express how useful this technique is. The difference between "It looks smooth to me" and "I know it's smooth" is a wide margin.
Computer cases in a boat thread? Blasphemy! Here is my practice testbed. I used this because I was about to throw it out, but once I had it all painted, I wished it was my actual case.. it looks stunning all painted up! Yes, I am a computer geek.
White versus Pearl - Battle of the titans! .. or something (Pearl is on bottom)
Light sources is what makes pearl stand out. Although the camera has a hard time capturing it, the left panel has a noticeable purple hue around the light. The greenish-yellowing, by the way, is caused be the fluorescent lights. The pearl apparently brings out the icky color of those, too.
The difference is subtle, but you can see the effects of the pearl on the right side panel as it moves from light to yellowish to light again. The left panel is white with no pearl.
Pearl paint aside, this is what I've been trying to eliminate.. the orange peel effect caused by.. well, I have no idea what. I have been able to minimize it in later attempts (this panel has been repainted a LOT of time, hehe) with a mixture of paint thinner and acetone as a thinning agent and some better gun handling. Although the latter is likely more influential.
vegasphotoman
Hi Lowkee and THANKS for the updates and pics1
photo the pearl in the sun...best way!
also....all paint has orange peel when sprayed...some worst than others...
automotive paints use REDUCER...not acetone or mineral spirits...so the results should be different when you spray the good stuff
Read the directions on the paint can and or on the manufacturers data sheet look online for thier PDFs that show reccomended spray pressures and such...I use a separate regulator and a little inline air filter for my setup (HVLP) It is usually at 25ps when idle, 10 to 12 lbs when spraying, when spraying is the important pressure! I go a little high on the pressure as my guage probably isnt accurate and sprays better a little high
To reduce orange peel, (this will be info for clearcoat as the base coat wont orangepeel)...spray a medium wet coat, let flash 5 to 10 minutes....then a wet coat....followed by another wet coat after the 2nd coat is flashed..should be tacky and not wet...(touch it in an inconspicuous area with the tip of your finger).....spray that last coat and let her dry.
HVLP use your bigger needle and spray tip (IE 1.7 mm tip) vs the 1.4 tip...clears need the bigger tip to get good coverage
a couple runs and sags WILL be INEVITABLE as you're spraying a vertical panel....try not to get too many runs....these will have to be sanded off using 800 or 1000 grit and polished out.....once it's all dry (next day)
after that you are DONE...you can leave it as is and it is fine....may have some orangepeel but look at your Ford or another cars paint..they have it too!
for a SHOW FINISH add a 4th and maybye even a 5th clear coat layer! 1/2 of that will be sanded and polished off...in the old days laquer guys would do 7 to 10 layers!!!!!
then carefully wetsand the whole shebang and polish it using finer and finer polishing stages...till super glossy no one said it was EASY ...it is however mostly LABOR INTENSIVE thats why a show finish / super smooth gloss etc is expensive!
Im not sure where you got your paint, but this is Middle grade single stage paint I used for my sterndrive and it will also be used for trailers (single stage polyurethane acrylic enamel white gloss)
I paid $110 per gal locally OUCH! $50 for wetlook hardener, $9 for the quart of reducer, $34 for the primer / $17 for the hardener for primer
online I found off brand paint with hardener and reducer included for $75 per gal
WEAR YOUR GAS MASK! and rubber gloves!
vegasphotoman
hey your new photos didnt load up! they worked the other day..
sorry to hear you're on hold!
best to ya and an early Merry Christmas! lol
Cheers
lowkee
Oh, crap! I reorganized my Picasa album and must have screwed the links. I'll get em fixed.
lekmedm
Awesome job on both the boat and this thread!!!
92excel
lowkee,
been away from iboats for a little, but you are doing great work.. I did mine last year and wish i had another to do this year.. when its all done you will miss the work you hated just a few months prior..
get back on the boat and get her ready!
vegasphotoman
Lowkee...I just read a thread that said BAYLINER will send you a free color owners guide / owners manual for your boat (in case you are missing that little piece of the puzzle) thye have misc ones from many many years going back 25 or more years in some cases....
I guess thier cust service is +AAAAA 5 star rated service and fast friendly etc etc and hey ITS FREE!!!! yea
heres the thread I found that info on...
http://forums.iboats.com/showthread.php?t=163290
For anyone else that's interested, I found the customer service phone no. for Bayliner. 360-435-5571. In Arlington, Washington. I requested an owners manual for a 1989 Bayliner 2755 Sunbridge and they said they would send it out - no charge. That was easy. Spoil me rotten!
__________________
Ron Everson
1975 Reinell 21' cutty cabin w/225 OMC
1989 Bayliner 2755 Cierra Sunbridge w/460 OMC King Cobra
lowkee
Thanks lekmedm. I hope you get out of it what you are looking for. Don't be shy, if I don't explain something well enough, just yell at me.
lowkee,
Welcome back, 92excel! I've been away from the boat for a month and I've already mentioned a few times to the wife "I wish I could be working on the boat". Too bad house stuff comes first. If I want to get my butt off to KY, the boat will have to wait.
Thanks for the link, vegas. I recall seeing that discussion a while back. It'd be interesting to see how much of the owner's manual still applies once I finish the restore :)
lowkee
QC pointed out that my photo links were dead again. I went through the entire thread and fixed all of the links. If I missed any or linked a photo which doesn't seem to match the caption, let me know and I'll get 'er done. Until I get back on the boat (January/February likely), at least you can reminiss by rereading all the old stuff ;)
mrlassi1
Your project has been an inspiration. Can you point me to the picaso link? I reveiwed the thread twice and could not locate the link. I wanted to find out what you did about the paint.
I've done four restorations using the Petit paint and had great results. After sanding the fiberglass I only used their primer and Easypoxy paint. The gloss and durability are outstanding.
I'm on my fifth project now, a 1976 AMF Crestliner. I'm learning lots about the OMC stringer drive system.
sprintst
That's some nice work. Been blasting through the thread.
Can't wait to see her all done up...
vegasphotoman
Happy Holidays to you and your family Lowkee!
:D
BobsGlasstream
Hey lowkee,
I hope that you had a safe and Merry Christmas too.
It's almost Jan. and I'm looking forward to seeing some more progress from you.
Bob
df909
Wow, this is the first time I've read your post but I think I'm going to print it all out and study it. I have a 1992 Capri 2050 with the 4.3L. You've done some awesome work. Want to come out to California for a couple months?
proshadetree
Hey man get that bayliner floating dont want to be the only one riding one of these.Best wishes for the new year and get to work That boat misses you.
bear_69cuda
Brutha,
Happy New Year!
ruckerra
I'm impressed! I paid $350 for a 62 Starcraft Arrow, trailer 55 hp Chryler and a parts motor. It's solid just dusty and not seen water since Carter was in office. I think your project WAY over my head. KEEPit up and KEEP POSTING!!!!
dragtuners
wow i have to say grate work i give u A++ on u had work and hope to see the boat in the water i will fallow
um0RION
Lowkee, just read the thread over again, and its making me itch to work on mine! My 1800 Capri doesnt drain the way it should, and those 2.5" drain holes have me drooling. The guy I bought my boat from had it uncovered, in the woods, right beside his shed, close enough so that when it rained, all the water from the roof went right into the boat :( Why people waste a good boat by not covering it is beyond me. Reading this again makes me want a garage to work on stuff like this. As it is I have the boat in storage for the winter (Maine, lotsa snow) and cant work on it till spring. Its looks like a LOT of work, but MAN... that boat looks fantastic.
If I ever did the floor in mine, it has the outboard setup so it'd be a bit different. Great to see how to do everything step by step, I cant wait to get updates on this in a month or so! I wanna see what you can do with the interior after the painting is all done. Keep up the good work!!
Status
