1990 bayliner capri cp 2070 , got myself into this
jbcurt00
Re: 1990 bayliner capri cp 2070 , got myself into this
You may be able to find any of the following in 1/2", 5/8" & 3/4" for rebuilding the stringers, transom, deck, seat boxes, side panels (may choose 1/4" or 3/8" depending on what was used originally):
Exterior Grade ACX plywood
Auraco
MDO (Medium Density Overlay(looks like it's covered by a brown paper grocery bag)) NOT MDF(medium density fiberboard, the sawdust & glue ply used in knock down, comes in a flat box, DIY furniture)
Underlayment
Douglas Fir Exterior plywood
Marine Plywood
Among others.....
Depends on where you live & buy lumber...
I can't answer your I/O swap questions
ricohman
I suggest "run what you brung". If you sink $2500 for another used engine/drive plus the cost of all materials for the resto it will by far exceed the value of the boat. And if its running great now why mess with it? Parts are always available used if you look around.
jcb996
Great info from you guys! Ok the stringers look like there about 3 inches thick, what do you do just put pieces of ply together ? Also foam what kind weight etc, and what is peanut butter? Sorry guys i can build a car from nothing, but boats i dont know the front from the back!
jcb996
Well decided im going to start this rebuild and im going to need a lot of information, everyone here has had some great advice, so any more info on materials needed would be great specific products and names! I have no clue on what PB is and these stringers are made of ! Deck and transom i can see but stringers dont apear to be ply but i cant tell for sure! So any info would help! Decided to stay with force and l drive for now!
jbcurt00
Auraco
Underlayment
Marine Plywood
Among others.....
There's a list of the plywood options, find & price locally for you
PB= Peanut Butter consistency poly resin based filler, used for bedding transom & stringers & creating fillets that allow the fiberglass cloth to roll smoothly across transitions between adjoining surfaces: transom to hull, hull to stringers, deck to hull sides etc...
PB can be made w/ or w/out fiberglass fibers, to repair minor dents & dings it's mixed w/out milled fibers.
For more significant damage or structural repairs, the milled fibers are added to the mix, this is often referred to as hairy PB.
Friscoboater calls the resin filler 'Pookie'....
Read thru all the threads in Don's How to post, particularly oops hull extension thread & Friscoboater's thread (his youtube channel is extremely helpful also)
Read thru WoodOnGlass' Blue Flamingo thread & the links in his signature line:
"Fabricating Decks, Stringers, and Transoms"
"My Flamingo"
"Building and Upholstering a Bench Seat"
"Paint Your Boat for Under $100 Bucks"
And get some pix posted in your thread.
jcb996
Just started reading all the info under sticky,
Kwasy Wabbit
How goes the battle with the boat? I have exactly the same boat and issues (only its a 1992).
jcb996
Slow so far , pulled most of the wood , down to the stringers , not much time , hope to have it all cleaned out before dec !
