1990 Celebrity Bow rider fuel cap
svish
Fuel cap took a swim and trying to locate a replacement. The standard 1.5 replacement caps are all slightly to large to fit into fill. Does anyone gone through this already? Suggestions, if i have to replace the deck fill will the fuel line and clamps come up with the fill or do i need to attach and reattach clamps in engine compartment?
Any help would be appreciated.
JorgeE
Re: 1990 Celebrity Bow rider fuel cap
Have not had to replace on my Celebrity, but on another boat we had I remember it being a fairly simple job: Remove screws holding fill to deck (may have to pry off to break sealant), pull out as far as hose will allow (without putting too much force on hose), loosen hose clamp, pull off old fill. To replace fill, reverse and don't forget to put back ground wire if there is one.
