joeltjen10
Thread starter- Joined
- Jul 18, 2016
- 54
No Title
It's been a few weeks but some progress has been made.
I went through and sealed all of the floors in the stern of the boat with 2 coats of epoxy on each side. Then I glued down the carpet making sure the top was smooth. Followed by flipping the floor pieces over and gluing down the edges but I did use a few staples to hold it in place. The carpet was time intensive but I found that just a light coating of glue was enough to hold it Using clamps with 2x4's along the edges to hold it tight was really effective. I would highly recommend is making sure you have enough clamps so you can do several pieces at a time easily and you aren't trying to just make it work
Now that everything is sized into place I can trim down the hatch and bow floor as it looks like I need to sand down between 1/8" and 1/4" to allow room for the carpet between the floor boards before I seal and carpet.
Only a few weeks left until the water is open around here!
