Re: 1990 evinrude 120 4600rpm WOT enough?
Credit to wilde1j for that.
Me and one helper did it in about a half an hour and we weren't in any hurry. It was exactly as easy as it sounds.
1. Park on a level, paved surface
2. Block car wheels so it can't move
3. Motor vertical
4. Place wood blocks under skeg until only small space
5. Remove upper engine to transom bolts
6. Raise tongue jack on trailer until slight load on skeg blocking
7. Loosen, but DO NOT REMOVE lower engine mounting bolts in slotted part of motor bracket
8. Continue extending tongue jack until hole you want lines up with bolt hole
9. Replace upper bolts
10. Tighten all bolts
11. Retract tongue jack
DONE
