1990 evinrude 28hp SPL idle and ignition timing
a1machinista1
Ok I will try to make this simple. I need some information on this outboard. I will be getting a manual but the local boat shop just took $800 from me so its going to be a couple weeks. So I need to know if anyone knows the idle speed? And what timng should be at that idle speed? Also what is the total timing a WOT? And last does anyone have a picture thay can send me showing the slow idle and fast idle locations?
I just bought this motor and it was missing at low speed in gear. I adjusted the idle mixture and it helped a little so I then adjusted the sync rod to let the ignition get a LITTLE more advance.. ( I moved the screw rod stop ONLY 1/16 towards the carb) I did not want to give it to much timing advance as I know I can burn this thing up quick if I am not careful. So now it runs pretty good but I want to go check timing at full throttle tomorrow. I will set it according to the post I read on here earlier. But I need to know total timing for this motor... Any help will be appreciated...
