1990 Evinrude 70hp bogs/dies off when moving into high gear
Status
Not open for further replies.
durban
Master Chief Petty Officer
What it ended up being, and this is very good for anyone with this engine is that Evinrudes were equipped with a system called S.L.O.W that kicks in when you have a problem with overheating or low oil to protect the engine it limits the speed. It was easy to check as there are two brown wires that disconnect the low oil and high temperature wires. I disconnected both and in ran perfectly. Reconnected the low oil and it died again. I checked the temperature and it wasn't running hot (used a laser thermometer). It turned out the temp sensor was broke causing it to register running hot and kicking in S.L.O.W mode. Replaced the sensor and all is fixed!
Thank you , i have learned something new from this .
Sirrobin53
Thanks for posting the fix. I like to see the outcome from a happy boater.:joyous:
phillnjack2
Ensign
I thought the motor died when put in gear . s.l.o.w mode will not stop it going into gear and carry on running.
slow mode just stops the motor from going over 2,000 rpm.
flyingscott
You are on the wrong post this one is 2 yrs old.
Status
