bktheking
Thread starter- Joined
- Jul 29, 2008
- 5,057
Hey all, it's been a while, yes i'm still alive and well and now messing with my own hunting motor. 1990 9.9 - we ran it last season without a hitch. This season, a week ago, we went out to setup for the hunt. Upon our return the motor smelled like it was burning- I put some water on the top of the block and it sizzled, yup it was overheating. Got it home and pulled the stat cover, it's a newer motor with the stat in the top of the head. They went cheap, some sort of bakelite housing with a swappable stat- no more metal. The "claw" as I call it that holds the mechanical portion of the stat and spring had broken. I could only find one piece of plastic claw so i'm assuming the smaller bits ended up in the water passage. We have since replaced the stat- the exhaust housing runs fairly cool to the touch on muffs, the water stream is good out the telltale and it gets fairly warm. My question is- the housing where the stat sits, is it supposed to get hot cause i can't hold my hand on it. I fear some part of the stat housing are lodged in the passages and restricting water flow. I know water is flowing to the stat cause we ran it briefly without the cover and stat, water came out the hole.
Thanks all!
Thanks all!
