1990 evinrude with s/n G02535055 pwr pack dva output?
csisommout
what would be the voltages from pin #1 and #2 from pwr pack when engine runs? thank you.
Daviet
Re: 1990 evinrude with s/n G02535055 pwr pack dva output?
Go to the CDI electronics website and look up your engine, all the specs should be there.
clanton
Give us model numbers, horsepower, wire colors.
csisommout
Have checked compression 120 and 118 psi, sparks test Jumped 7/16, ok with timing light, the light not flashing bright. pulled 1 plug at the time won't run on 1 cylander.
Dealer replaced coil. he said electrical problem. need time. I also disconnect tan wire from temp sensor and grounded out still the same.
also check DVA output according to CDI websit getting 2.6v and check input voltage of coil that coming from power pack, yellow green and yellow blue get 4v.
getting confused. any info or ideas will be appreciated.
csisommout
the wire is brown to brown/yellow. model#VE50BELEESR. thank you
csisommout
50 hp, model# VE50BELESR. UPDATE, ALSO CHECKED 2 YELLOW/GREEN AND YELLOW BLUE POWER PACK OUTPUT WIRES READ 19MOHMES. IS THAT GOOD PWR PACK.
THANK YOU.
csisommout
Any thoughts or info..? thank you.
clanton
This engine has the ignition module under the flywheel. Voltage on the yellow/blue, and yellow/green should be 175 volts or higher at cranking rpms. Red lead to primary side of coil, black to ground. Spark plug wire connected to spark tester or sparkplug with plug grounded, you want the spark to jump a gap. The same test with plugs in and engine running, voltage should be 200 volts or higher. Charge coil ohms 560 +- 25. There is no voltage spec for the charge coil, because you have to remove the flywheel to get at the wires.
If ignition module is bad, replace charge coil with the new module.
clanton
If you are using a DVA adapter, meter should be set on DC scale 400 volts.
csisommout
I use digital multi meter. it reads only 4 vdc on both red/green and red/blue to ground. I plan to take out fly wheel. is there anything else such as voltage regulator can that low o/p from pwr pack? thank you
