1990 extd 225 yamaha electric chocke not working
MID FL CAP
Hello,I have a 1990 225 yamaha that I can't seem to get the choke to work. I have inspected the diaframs, and it is o.k., cleaned all the leads to it I could find,still not working. Is there i am missing? I admit I do not have a manual,maybe someone has one on pdf? Anyway, I stuck with no choke,can anyone point me in the right direction,I would apprectate it.Thanks!::)
MID FL CAP
Re: 1990 extd 225 yamaha electric chocke not working
Note to self- I checked for power at switch(blue wire hot when pushed in)had hot wire all the back to engine to were it goes into computor,and stil nothing,choke not flodding engine while running,it mflood with red tab up.O.K.is there anybody out there?????:):)
rodbolt
you should have two soliniods on the upper pump labled A and B.
the push to choke function has no affect on that motor if you have A and B solinoids.
cold start enrichment is based on a signal from the engine temp sensor and controlled by the ECU.
MID FL CAP
THANK YOU,rodbolt! So I am to understand that choking is not needed on this motor.Just turn the key and your good to go? Thanks again!:)
