pooh_b_21632
Thread starter- Joined
- Jul 26, 2009
- 31
Beginning of the summer I took my boat out and the original problem was an intermittent misfire. After talking to this person and that person and reading forums, and my manual we have replaced alot of parts. Took the boat out today and runs phenomenal compared to before but still has a slight intermittent misfire that irritates me. My last thought is that I should replace the coils. It has the prestolite ignition with the original now 21 year old coils with the original plug wires built in. I feel that could give me the intermittent misfire but want other opinions.
List of Replaced/Cleaned Parts/Items:
1. Cleaned and emptied fuel tank
2. New Fuel Lines
3. New Fuel/Water Separator
4. Cleaned/rebuilt both carbs (went throught them several times and I could now disassemble them with my eyes closed)
5. Rebuilt fuel pump
6. New NGK spark plugs
7. All four Pistons/Rings/Wristpins/Bearings are new (they were missing chunks of metal from them original owner either ran it too lean for too long or over heated it)
8. Many new gaskets
Once I got the pistons replaced and we put it all back together (after cleaning the carbs again) it started good but idle was rugged so checked the timing it was off so we reset it, now at WOT it goes to 30 degrees BTDC where the manual says it is supposed to be at. We had the carbs at 1 and 1/2 turns out but it was too rich and I was having trouble getting it to go into gear without dying. Now carbs set at 1 and 1/4 turns out runs great starts great goes into gear without dying. only problem is intermittently without a specific pattern or cause the engine will buck or jump real quick then return to normal sometimes it does it a few times sometimes only once. We circled the river many times it only did it maybe 5 or 6 times but its irritating and I want to fix the problem before I have another expensive or time consuming repair. The coils were arcing once before you could see it in the dark but I put dielectric grease around the coil where the sparkplug wire comes out and in the spark plug boot of each one and the arching stopped. I think I need to Just replace the four coils and plug wires. Anyone else have a similar issue? or any other ideas or thoughts?
2. New Fuel Lines
8. Many new gaskets
