1990 Force 120 L Drive... runs, but no power at WOT
brandonv
I just picked up this boat last week and the first 3 trips went without a hitch (except the batteries wouldn't charge).
This week I replaced the two dead batteries with one Costco marine/RV battery and installed a new head unit and speakers. I headed to the river and boated for 30-40 miles before stopping and having lunch on the shore. After lunch the battery was not cranking the motor over well and I eventually needed a jump to get it fired up. Once I got it fired I decided to head back to the dock, got the boat on a plane and then after 20-30 seconds on a plane it lost half or more of its power. The motor still ran (and sounded good), but the RPM's would not get high enough to get the boat going over 10MPH. My tach showed I was running 4000+ RPM's, but it sounded more like 2k- to my ears. It was almost like it was starving for fuel, but the bulb had pressure and the filter was clean.
I also made the mistake of disconnecting the battery cables while the boat was running to check for a bad connection. As I was re hooking them up, my head unit 'popped', started smoking (its a goner) and my voltmeter went from its usual 13.5-14.0 range to pegged at 16.
Any speculation as to what happened? Can removing the battery cables while running kill the voltage regulator? Can this all be tied into the loss of power?
Thanks!
QuadManiac
Re: 1990 Force 120 L Drive... runs, but no power at WOT
You don't have a voltage regulator, the stator windings are recitfied to DC and the system depends on the load of charging the battery to keep the voltage from going thermonuclear (as you unfortunately experienced). You must not disconnect the battery while the engine is running, period.
Sorry, you have likely damaged some of the motor's electronic components.
brandonv
Any speculation as to what may have fried?
I've found the rectifier, but cannot find a test procedure in the Cylmer manual I have.
I've got deeper issues than electrical problems since my power loss came before I even messed with the battery. Nice welcome into boating :(
Nate3172
The Clymer manual I have, (B751-4 4-150HP models 1984-1999 including L-drives), shows how to test the rectifier on page 47 under Troubleshooting Nonregulated Models.
brandonv
Thanks man! That's exactly where it was.
