DukeDelago
Thread starter- Joined
- Jul 17, 2009
- 46
My l-drive 120 hp force is lacking power at WOT. Compression is 125 on all cylinders and the motor starts, runs, and idles perfectly. My problem is trying to plane and maintain cruising speed, on good days I can turn around 4500 rpm (used to do 5200) and on bad days maybe only 4200. My initial thought is the coil and wires since the carbs have been torn down and cleaned several times with no change in performance and compression is good. I have used an in line spark tester and all four cylinders are getting spark, at least at low rpm. I'm wondering if at higher rpm when the cd modules only have time to fire once per cycle I'm getting intermittant spark on one or all cylinders, causing this power loss. Any thoughts??
