Got a 1990 Force 120 that's running lean and popping. Prior to this, I pulled the carbs, replaced carb gaskets, checked reeds, checked spark, and compression. I basically I did all the preliminary diagnostics before I arrived at this conclusion, with the help of an automotive mechanic friend.
It smooths out and runs great when carb cleaner is fed through the bottom carb. There has to be a leak somewhere behind the carbs causing this lean condition, right?
Anybody have any idea what's going on? Is this a common occurrence with these motors?
Thanks
Thanks
