1990 Force 120 No #4 Cylinder
bigmatt14
First post guys. Great forum.
I have a 1990 Force 120 that is running on 3 cylinders. The #4 cylinder isn't firing. Compression tests match top to bottom, as does the spark in all 4 cylinders. Sprayed all the intake gaskets trying to create a seal in case I had an intake leak and nothing.
Anybody have any idea what's going on, good compression, good spark, new plug, still not firing?
Thanks for the help guys.
bktheking
Re: 1990 Force 120 No #4 Cylinder
Stuck open reed will do this, causes the cylinder to fill with too much fuel, compression and spark check out but it just won't fire.
Been there with the same issue, just a different motor.
bigmatt14
Can this be cleaned and fixed, or does this have to be replaced?
roscoe
replaced as they are usually bent or broken
thompy
ccms after market reeds are under 100 dollars, boysen a little over, but sound like the boysen dont hold up as well, the stock ones are steel dont have a clue on price, the reeds are in behind the carb manifold
bktheking
All depends on the situation, in my case a zip tie was stuck in the reed plate holding a reed open, all I did was remove the tie and I was back in business. Reeds aren't expensive, you'll need to pull the carbs and manifold to investigate.
