1990 Force 150hp O/B - New Boat Owner
KBHicks88
Hello everyone, I recently purchased my family a 1990 Bayliner Cobra 1904 with a 1990 150hp Force Outboard. I will admit that excitement kicked in when I fell in love with the boat which caused me to make the purchase before I looked any further into what I was purchasing. Now that I have the boat and was looking to take it in to the local shop to have it looked over and a tune up performed, I was informed they did not service this motor any more, along with all other shops in the area. So I have done some looking around on the forum before joining and decided that with the experience here that I can get this beauty running awesome.
I did purchase the boat lake ready, but I just do not believe I am getting everything that I am suppose to be getting out of this 150hp. When on the lake at WOT I am running around 4000 rpm which puts me roughly at 35mph. I am going to purchase a compression test gauge this weekend hopefully and see what pressures I pull there, and replace all the plugs. With this all being said, what other items need to be addressed before the season truelly gets here so that I can have then family out on the water.
I am sorry for the New-B questions, but I have tried using my masters in Google, but just have not found much information for this motor, or the boat for that matter. Thanks, and I look forward to being here and learning lots from everyone
pnwboat
I have a 1988 Cobra with a 1988 125HP motor that's been slightly modified. You should be getting more speed and RPM's than what you stated. It's a good thing to check the compression. Also look at the Propeller. You should have no more than a 19 or 21 pitch prop for a 150HP motor on that particular hull design. There should be some numbers on the prop hub.
KBHicks88
When I perform the compression test, what PSI should I be looking for? I have also seen talk on another post discussing decarbonizing? Is this necessary and how exactly is it performed, once again sorry, still trying to learn
KBHicks88
I will have to check the prop once I get back into town, I had to leave for a few days for work.
pnwboat
Compression readings are somewhat subjective and it depends on who you talk to. Generally 100PSI would be minimum. 125PSI average and 145+PSI would be factory fresh. More importantly is that the highest and lowest readings vary by no more than 10%.
Decarbonizing gets rid of carbon deposits on the tops of the pistons, cylinder heads and in the ring grooves. Excessive carbon on the pistons and cylinder head may cause pre-ignition, and in the rings grooves, it may cause the ring(s) to stick resulting in a poor seal and low compression.
It's only necessary if you have excessive carbon build up. If the motor is running as it should, you shouldn't have to do it.
SkiDad
my dad has an 88 Cobra too (different design) - 18' and force 125 - stock and it goes about 38. I would think you should hit low 40's without too much problems. I wonder if one of your cylinders is not firing - you can test for spark on all the cylinders by putting a timing light on each lead or get an inline spark tester at the auto store for 10-15 bucks. or maybe it just needs to run for a while to clean out all the junk. I'm sure you are aware, but if not, you need a 50:1 oil mixture in the gas. And you could try some mercury quickleen in the tank too.
KBHicks88
Thank you everyone for your responses. I will be checking the compression this weekend, and will let you all know what I find out on those results. I am going to also be purchasing new plugs since I am not sure the last time they have ever been changed.
SkiDad, thank you for the response. I am hoping that after little time running the motor and getting all the crud out from sitting, that it might begin to improve. I keep reminding myself at the same time that it is 26years old and at new it was advertised to run 46mph. I will take the suggestion on the quickleen though, and get that added to the tank as well.
jerryjerry05
My twin 88/85's still have the original compression.
With a GOOD gauge the readings should be about 145
Forces, unless they are carboned up should always have about that(145+/-)
I think the 90 150 still had the comp readings that the older Force/ Chryslers had.
In 91/92 after they stopped the 150 they started making motors with different comp ratios. Top and bottom were something like 160 the 2 centers were 145.
Now depending on your gauge???? Your readings should be within 5# of each other.
If all 5 are about 120 then the low reading is probably the gauge.
Any more than 10# will indicate a problem.
​If my motors don't start right away I do a comp test.
