Re: 1990 Force 90 idle problem/ Motor dies in gear
I own the exact same motor 1990 FORCE 90. First of all when you shift in gear, make sure you do it quick. The idle dead-zone on the throttle is large due to the shifter cams that operate gears. If you take your time moving through it, the engine will bog down due to prop being engaged. Unless you quickly add power to overcome this RPM loss the engine won't have enough momentum to turn over and will die. First time I got my FORCE 90 on the water, I was not used to it and thought something was wrong with it.
Also, you can adjust the idle screw, just be careful not to over-rev the idle otherwise you will start grinding the gears in the lower unit when shifting.
