1990 Force 90hp - exhaust air in Motor compartment
Capri90
Hi.
First off, I am sorry for my english it is not my first language.:redface:
I bought a 90' Bayliner capri with this 90hp Force motor.
Right from the beginning I had trouble with it.
First the head gasket was leaking - fixed
Then the choke didn't work - fixed
after that it ran like a champ with the ear muffs on.
then we launched the boat for a watertest and the motor stalled after running for a couple minutes. As I took the cap of to see why, the motor compartment was full of exhaust air. My problem is I can't see where it is comming from. And it doesn't happen with the muffs on.
Maybe anyone knows where.
I couldn't find anything in the search.
Thanks
Bobby
jerryjerry05
Re: 1990 Force 90hp - exhaust air in Motor compartment
Run it in the water and check where the exhaust is comming from.Could be as simple as a rubber hose or as expensive as a base gasket.
#5 or #24 or under the powerhead.
Capri90
Thanks for the quick reply.
I had the boat in the water again and it is bubbling at the front of the motor, so It can't be #5 i guess.
it could well be #24, do I have to take the powerhead off to get to it?
I could answer all upholstery questions, but i'm absolutely unexperienced in motors.
Thanks a bunch
Bobby
