MountainManMyke
Thread starter- Joined
- Sep 25, 2010
- 88
Had the boat out this wknd and ran into some stalling issues. Started the boat on the dock and it ran perfect, once it started to get warm it’s stalled out. Went to turn the key and it turned over longer than usual, finally fired back up. Ran for a couple mins and had the rpms at like 2000 and started to die out and stalled again. When the engine died it sounds like something is bleeding off for about 3 seconds. I changed the water fuel separator on the fuel pump housing and it made no difference. I tested voltage at the alternator and it was reading 1.6 volts on the heavy red wire. Not sure if that voltage is normal because it’s regulated, battery wasn’t dying or anything, motor cranked fine. Not sure where to go from here, if I should change the alternator or keep investigating to a fuel delivery issue. Thnx guys
