1990 johnson 115 and 2000 johnson 90?
DavidD
Could someone tell me if the control box connections and the rest of the wiring on a 2000 Johnson 90hp the same as a 1990 Johnson 115? The 2000 is on a pontoon in the water and I cannot see what kind of plug it has for the control box. Nor can I see the plug for the VRO tank. Any help would be appreciated. Thanks!
boobie
Re: 1990 johnson 115 and 2000 johnson 90?
The wiring harness and connections are different as they came out with System Check in '96. Control cables should work.
DavidD
Okay Thank you!!!!
