metriccrescentwrench
- Joined
- Oct 22, 2007
- 2,598
I took a new to me '90 Johnson 200 out for the first time yesterday and it didn't run well at all. To top it off the overheat alarm sounded after 15 minutes so I idled back to the dock and put the boat on the trailer (the alarm stopped after a couple minutes of idling). It has a brand new water pump, and water pressure was between 20 and 25 psi at all times when running above idle. I didn't have a lot of time to troubleshoot it last night, but did do a compression check and the numbers have me a little puzzled.
On the port cylinders I got 80, 76, 72; and starboard cylinders were all 72. That seems low, but since they're all close I wonder. I realize different compression gauges will read differently, as a point of reference my gauge shows numbers between 110 and 120 on my '81 Johnson 90 HP.
