1990 Johnson 70 HP Engine cuts out
mr_clean_na
I purchased this motor a month or so ago. It seemed to have fuel problems and was cutting out. I took it to a shop and they rebuilt the carbs. The motor had a electric fuel pump which only put out 4 1/2 psi so I replaced it with a 8 psi pump. This seemed to solve the problem as I went out and drove the at full speed around the whole lake ( 10-15min) before it started to sputter and only go half speed. So I took it to shore let it sit and again took it out and it went full speed for about a minute before sputtering again all the time the fuel pressiure gauge styas at 8 psi. I could realy use some help with this. Any suggestions?
