havoc_squad
Thread starter- Joined
- Mar 5, 2011
- 741
1990 Johnson 90hp VJ90TLASB model.
Backstory:
After doing a VRO delete, carb rebuild, impeller replacement, throttle sync per service manual, and addressing minor time consuming issues that came up.
I was finally able to get the motor running today and seemed to do fine on the muffs, except that there was too much play in the throttle cable in and idle was much higher than I was expected. Was probably about 1500 to 1900 and the gauge wasn't working on the dash.
I had the cover off, pushed the throttle arm back down to the idle stop to take up the slack and things settled down to probably 1000 rpm. (When the engine was turned off, I adjusted the cable lash/takeup and resolved that but didn't get to verify that fixed that issue.
Just for saying purposes, I did what the manual specified on the throttle arm to verify the carb sync roller is moved to where the arrow is pointing in the middle with the butterflies closed on the carb and that the carb arms do NOT move.
Not knowing the history of the motor, I had an infrared temp gun out checking the cylinders as soon as the idle stabilized.
I had a full strong tell tale stream and it appeared a reasonable amount of water was coming out of the exhaust hub.
So, I watched the temperatures climb on my temp gun, and the result was:
Port cylinder head stayed steady around 157 to 160'ish degrees F
Starboard head increased to about 180 to 189 degrees F. Soon as this stayed this amount more than about 10 to 20 seconds I think, I shut the engine off and did not restart it. There was no alarm that went off and I did verify the overheat buzzer worked on the control box per the service manual on the starboard side cylinder temp sender wire.
Also, I have a small leak around the bottom port side of the exhaust cover plate likely where the gasket area is, not a leak around the port cylinder heads.
So, my questions are:
1. Is there any situation where I may have prematurely assumed an issue here but there is not?
What is the best procedure on this model of motor since the thermostats likely require a powerhead removal to access? Remove the starboard cylinder head and look for issues first, then if nothing is found have the powerhead pulled and get the thermostats and power valves replaced?
Once the issue is narrowed down for the starboard overheating, replace all applicable exhaust housing gaskets?
2. Was the throttle/carb linkage synch procedure performed the correct way, or was I reading it wrong? Just for saying, I have not had time to verify idle timing, nor do the Joe Reeves timing steps for non-running max timing test. None of that has been disturbed by me, just saying since it's "new to me".
3. Tach was acting wierd, barely moved and sometimes would barely show a reading. Was too busy concentrating on engine sound, getting the idle down to normal, and checking engine temp. How is the outboard tach tested on instrument gauges?
Backstory:
