gonefishin485
Thread starter- Joined
- Jun 29, 2008
- 108
so over the weekend i bought this motor, 1990 Johnson GT 150 V6 with the 35 amp stator and 35 amp water cooled regulator/rectifier. i bought it from a guy who seemed genuine with the understanding he had the motor at a shop and ran out of money to fix it, so therefore he sold it. according to him, the shop put a new power pack, and 1 new coil and said it needed a new trigger. i noticed when i took the starter off to clean the commuter and brushes that the regulator rectifier wire that went to the starter solenoid had a cdi electronics tag on it, so im going to assume thats fairly new as well.
the previous owner was telling me the motor would run, then it wouldnt. he took it to the shop, the shop had it running and called him to pick it up, then called him to tell him it wasnt running again. it was an intermittent spark issue. when i got it home and on a stand, i did the obligatory spark test, and my results were on the port bank i had fire on the top and bottom cylinder, nothing on the middle cylinder, and nothing on the starboard bank. (however it is worth mentioning that during testing the plug boot and clip came off the middle cylinder plug wire and while holding the bare wire trying to jump a spark, it shocked the **** out of me) if i swapped the leads from the power pack from a firing cylinder to a non firing cylinder, i could get every coil to throw a hot blue spark.
after about an hour of messing with it, it lost spark altogether. so i dug out my clymers shop manual and ohm meter and started testing. from the two charge coil test points the manual claims i should have 985 ohms +or- 25 ohms on both sets of wire pairs. max ohms i was getting was in the 820 to 840 range. i would have tried testing the timer base, but in the manual it shows an isolated ground wire that needs to be disconnected to ohm the timer base, and for the life of me, i cant find that isolated ground wire.
so what are the chances its the stator? or could it be the trigger as he called it, but my research shows its called a timer base. i wouldnt mind replacing both parts but seeing as both parts are in the 300 to 400 dollar range, ideally id like to replace the bad one.
any thoughts?
any thoughts?
