1990 johnson vro 70 HELP
wesgore92
The motor has good compression at 140 on all 3 cyl. The motor idles fine but will run rough at wide open... timing is advancing correctly carbs have been rebuilt twice tryin to fix this problem... All electonic ignition compenents recently replaced ive never seen this problem any help would be nice sounds like it just stallin at wot and wont push boat on plane
Daviet
Re: 1990 johnson vro 70 HELP
Have you checked the fuel pump flow and pressure, does pumping the primer bulb help the problem any?
wesgore92
The carbs are pumpin fuel like crazy but maybe the lift pump is weak ill look at it and see
