1990 marine 4.3 CAM AND LIFTERS
Captaindillon
I’m new to marine and i bought a 1990 fourwinns 195
and the motor is locked up.... so I’m rebuild it with my grandpa.. does anyone have a list of parts they used? I need help Finding a cam and lifters...i got the crank and pistons
Howdy
If you can find the motor serial number we can post a link
Look above the starter for a plate on the block
Oh just noticed that's an OMC, and the distributor is an automotive type which is a no, no for marine
The motor should be a GL something
Lou C
at that time the OMC model numbers would be like this:
434APRGDP (mine)
this translates as
4.3 engine
4= 4bbl carb
A= first run of this model
P= power steering
R= right hand rotation (standard) as you face the front of the engine
GDP= 1988 production
your model # is probably on that port side valve cover....take a look....silver colored sticker.
the cam and lifters should be a GM roller cam and lifters. That's what mine had, and when I replaced the heads 2 years ago they were all in good shape. Minimal to no wear.
You have the OMC bat wing one piece manifolds, if the engine was locked up these could have failed, either rotted through or cracked, figure on replacing these and upgrading to the later 2 piece style exhaust like I did when I did the top end overhaul. It can be done with Barr aftermarket manifolds and elbows, and Volvo Penta 90* exhaust pipes & hoses. It all fits like factory and no leaks. I had the batwings on mine too, but I never kept a set on more than 6 years because were are in salt water and never had a leak from them. The pic below with the red Volvo 4.3 shows what that exhaust system looks like from the rear, the next is my installation...those Volvo parts are expensive but you can find good freshwater used ones if you look on ebay, or GLM makes a knock off of it, I used the Volvo OEM because I'm in salt water and wanted no fitment issues or leaks.
Yep you have to get rid of that auto distributor, you can either try to find a Prestolite points distributor, I have found a couple on ebay for spares, or convert to the Delco EST, if you do that you might have to change the ESA module to one that works with electronic ignition. I bet it was changed because by then they might have used the Prestolite BID system (electronic) for which you can't get modules, although you could have converted it to a Petronix. Mine has the standard points and condenser set up.
my recommendation. buy a newer running 4.3, preferably 1996 and newer.
you will need to get new exhaust manifolds.
then buy a proper marine distributor, verify the alternator and starter are marine or buy a new starter and alternator.
cam can either be the factory GM marine grind for the 4.3 or either Crane or Comp cams marine grind. get the lifters with the cam.
Lou C
Also while it may seem that the engine was locked up, if the drive is still on, it could be locked up and not allowing the engine to turn. Might want to pull the drive off first, before pulling the engine apart unless you know for sure already.
bruceb58
Honorary Supreme Mariner
Out of curiosity, how did that drive shift out of gear with that auto distributor on there?
Captaindillon
Here’s the block number!! I think my pistions look good too i may just put some new rings in... soo i need part numbers for
-rings
-Cam & lifters
-gasket kit
Also need a new distributor any ideas?
Captaindillon
Also chain and gear set!! Need part numbers and stuff
Captaindillon
This is the intake numbers too
