Putzaroni1
Thread starter- Joined
- Oct 20, 2012
- 108
I am pretty new to Mercs but have been digging here and can't find anyone with the same issue. I'm probably missing it but here is the situation. I have our 8hp kicker for our boat and fogged it 2 winters ago. We didn't try to start it last year at all. I pulled it out and put it on the boat hoping to just fire it up but nothing. I then took it home and about 3 hours later tested for spark and while testing it, 2nd pull it fired right up but I didn't have it in water so it ran for about 30 or 40 seconds till I found the on/off switch. The next morning I figured it would just be a matter of putting it in the tank and letting it burn off the fogging oil and while it did start briefly, once it stalled I have not been able to get it to fire again or even sputter.
Here's what I've tried.
1) I put my spark gap tester on and it has a strong spark from both cylinders with a good snap about 5/16ths inch
2) I replaced the plugs with the original champions even though the other ones were pretty clean
3) I poured a little bit of fuel into the spark plug holes and still no firing or sputtering.
It's like the on/off switch is in the off position.
This thing was all tuned up and running perfectly when I put it to bed with the fogging oil.
What else can I try ?
Thanks for any suggestions
