1990 Mercruiser 4.3 V6 pictures needed!!!!
dbk227
Any one out there have a picture or 3 of the 50 amp Circuit breaker mounting position on the engine block?????
Thanks guys!!!
Re: 1990 Mercruiser 4.3 V6 pictures needed!!!!
What is the issue you are trying to fix with the need of pictures?
jonny rotten
I have the same motor same year and I just changed mine last week?Do you still need a pic?
Don S
attachment.php
dbk227
Absoultely!!!! What I really need is pictures of the Wiring harness routing from the alternator to all of the end points!
Thank you!!
dbk227
I'm in the final stages of a rebuild (motor was received already dis-assembled). Clymers guide has been great, but lacks certain details. I had been having difficulty in gauging how the wiring harness routes. Unfortunately, I haven't been able to find any good diagrams/pictures for this. However, I just watched the video which helped immensely! I can see that I put the coil on the wrong side of the distributor, (as well as the rear lifting bracket). I'll make the adjustments & post again later with some pics
