Re: 1990 mercruiser engine alignment tool
Just an FYI on the subject when someone does a search and finds this post.
Using an old shaft will work ok to verify the alignment is good, just by the fact that it will go into the splines and pull out easily, but that is the limit of their usefulness. However, they do not work well for trying to align an engine, or adjusting a gimbal bearing after replacement.
Without a handle, you can't use it to adjust the gimbal bearing, nor can you use it to align the engine because you can't hold on to it.
Even if you welded a pipe to it to make a handle, there is so much surface area with the splines that you can't read it like a smooth alignment bar to determine which way to move the engine to align it.
