1990 mercu 60 with power trim and tilt
wolfie-uk
Hi, how heavy is this engine as i need to know weather to buy it for a RIB i am interested in, as the transom has a max rating weight wise
regards
RLT III
Re: 1990 mercu 60 with power trim and tilt
Outboard Motors
1990 MERCURY
MERCURY MARINE
2-STROKE SERIES
60ELPTO
Motor Type: Gasoline
Volts (Electric Motors): N/A
Thrust (Electric Motors): N/A
Horsepower: 60
Cylinders: 3
Start Type: Electric
Dry Weight: 188
Power Tilt and Trim: Yes
there you go hope that helps
wolfie-uk
hi
Dry Weight: 188
guessing thats in lbs and not kg ? only the transom is rated in kg, 90 to be exact, so if my maths is right the engine weighs 85.2kg damm close to the limit if that is the case.
boat should be pretty damm quick though.................
Many thanks friend
