K.Runyon12
Thread starter- Joined
- Jun 4, 2022
- 3
I have a 1990 Mericrusier 3.0 inboard. It turns over but it doesn’t always crank. I am looking for some possible help. (It has a brand new starter on it and brand new spark plugs.)
Turn over = crank.It turns over but it doesn’t always crank.
Yes it turns over/ cranks but not alwaysTurn over = crank.
Are you saying the engine turns over/cranks but does not always start/run?
Or
The engine occasionally turns over/cranks, but not always?
The points are newDid you service the points?
Follow the troubleshooting guide in the stickies for engine's starting systemYes it turns over/ cranks but not always
Did you file them, did you set the dwell with a meter? Did you reset the timingThe points are new
You need to set up a few test points so you can immediately check things when the fault shows.Yes it turns over/ cranks but not always
