1990 OMC Cobra Stalls(4.3L)
89glasstream
Re: 1990 OMC Cobra Stalls(4.3L)
Everyone seems to think is has something to do with the fuel system, but it sounds like what was happening to me last year. It was the ignition sensor. That was on a Merc. Don't know about OMC.
ENSIGN
Unscrew the W/S filter empty this into a clear jar letting it settle for awhile.GOT ANY WATER?
dogboy7301
Ok, took off the nut on the carburator and nothing. If it helps, it's a 2 barrel carburator.There isn't a filter there. Bout a week ago I bought a carburator kit and I don't remember seeing it then. When I took the carburator apart I was very surprised on how clean it was. But replaced gaskets, accelerator pump, etc. Checked all fuel hoses. I guess the next thing will be to check the check ball on the pick tube or the ignition system. No water in the fuel. Tried removing the pickup tube when I drained the tank. Thought maybe it may be clogged but could not get it off. Any thoughts on a easy way to remove it?
dogboy7301
Ok, took off the nut on the carburator and nothing. If it helps, it's a Holley 2-bbl carburator.There isn't a filter there. Bout a week ago I bought a carburator kit and I don't remember seeing it then. When I took the carburator apart I was very surprised on how clean it was. But replaced gaskets, accelerator pump, etc. Checked all fuel hoses. I guess the next thing will be to check the check ball on the pick tube or the ignition system. No water in the fuel. Tried removing the pickup tube when I drained the tank. Thought maybe it may be clogged but could not get it off. Any thoughts on a easy way to remove it?
Juniinc
Good job!!
Don't you just Love it when a plan comes together?
Yup, the pick up line is usually stuck good enough won't even budge.
loosen the clamp then unscrew the threaded piece,,,
that should break it loose from the elbow fitting.
starsnstripers
This is a 2 barrel carb on a mercruiser but if you look at # 29 it's a filter. I'll see if i can find the OMC parts break down. If someone removed it before you then you may have a crapped up carb from it being missing.
starsnstripers
This is the filter for a 4.3 Cobra 2 barel carb.
dogboy7301
Ok!! I double checked the exploded view of both the Holley 2 and 4-BBL and neither had this filter. I then looked at the rochester carbs and they had this filter u r talking about. Will a clogged fuel tank vent hose cause my problems?
bruceb58
If you want to know if its the vent or not, you can run without the gas cap to see. Personally, I would run with a portable tank to see if your problem is tank related. Once you know it runs or does not run that way, you have divided your problem in half and can determine your next plan of action.
