1990 sea ray 200br with a 4.3 mercruiser and alpha one drive
jkeating
To start off as the title states i have a 1990 Sea Ray 200BR with a 4.3 mercruiser and alpha one outdrive.
Im in need of some help finding a hand full of parts. I want to order directly through iboats and want to make sure i get all the right parts.
Here are all the numbers off the plastic motor cover;
Engine #
0C865660
Transom #
0D334351
Drive #
0D326764
Engine - MCM 4.3
Displacement - 262CID
Spark plug # - AC-MR43T
Spark plug gap - .035
This is a whole list of parts that i need:
Spark Plugs
Spark plug wires
Cap
Rotor
Carb rebuild kit?
Oil filter (on the block)
Oil (how much)
Power steering fluid (just need to add a little not sure on what brand)
Fuel Filter
Lower unit Oil (how much)
Trim position sender
Impellor
Fuel rejuvenater (boat has been stored all winter)
I would appericate all the help i can get as i said before. I would just like to get it all off here but am trying to make sure i dont get the incorrect parts.
Re: 1990 sea ray 200br with a 4.3 mercruiser and alpha one drive
Engine #
0C865660
Transom #
0D334351
Drive #
0D326764
Engine - MCM 4.3
Spark Plugs
Spark plug wires
Cap
Rotor
Carb rebuild kit?
Oil (how much)
Fuel Filter
Impellor
Ayuh,.... I ain't lookin' up all yer part numbers for ya,.....
But,.....
I can tell ya there Ain't No such thing as That,....
Rotten gas is Rotten gas,... There ain't No Fixin' it....
jkeating
Rotten gas is Rotten gas,... There ain't No Fixin' it....[/QUOTE]
how do you figure its rotten? its sat over winter? i should be able to put octane boost in it or something since i put stabil in it before storing?
jkeating
Any help would be appericated. As for looking up parts i have no clue what im doing
Don S
Go to this link https://webapps.brunswick.com/literature/literatureSearch.do
Type in your serial number and you have every OEM part number for your engine and drive.
You can then use the OEM to convert to aftermaket parts.
Just look at the parts links icons above this post. iboats sells parts.
If you have problems finding or converting a number, ask, but don't expect everyone to lookup all your parts for you.
jkeating
as for parts, what better quality? Mallory or sierra?
[175] 4.3 (262cid) 2bbl V[6] 1985-1993 6919656-0F000877(13) 18-5274 - 9-29317
[185] 4.3 (262cid) 2bbl V[6] 1985-1993 6919656-0F000877(13) 18-5274 - 9-29317
[205] 4.3LX (262cid) 4bbl V[6] 1985-1996 0A331455-0F802999(3) 18-5274 - 9-29317
How do i know what motor is in it? I know its a 4.3 with 262cid?
jkeating
Ok so i found most of my parts... As for impellor, i cant find the right kit? The oem number i came up with was
47-89984t5
Im wanting all the gaskets with it, not just the impellor blade...
