1990 Sylvan Offshore
boston 6902
The original sticker is long gone from the valve cover so I cannot find the serial number. Is there any other way of identifying the engine so I can get parts. The Engine block is stamped with OMC, GM and made in Mexico I think.... The only numbers I have been able to find are on a raised plate right below the starter and distributor cap. M02278RB/T1038034.... Then on the block further back are a couple numbers but I can only read on - 2772287. Any help would be greatly appreciated.
Ayuh,..... Welcome Aboard,..... 1990 will be a Cobra drive,.....
How many cylinders,..??
4 would be a 3.0l,....
6 would be a 4.3l,....
An 8 will be a SBC, either a 350 or a 305,....
boston 6902
yeah, sorry I left that out. It's a 3.0 4 cylinder. I'm trying to find out the year, make n model of the engine. I found out Evinrude/Johnson bought out OMC. I called Evinrude and had to send in some pictures of the engine because there are 2 models for that year. Waiting to hear back from Evinrude/Johnson....
Ayuh,..... I think you'll find Bombardier bought out OMC corp, dropped OMC into the dustbin of history, 'n spun off Johnnyrude into it's outboard division,....
southkogs
Usually on the older OMCs there was a tag on the engine - toward the rear, usually on the starboard side. A 1990 3.0l OMC would have a model number like 302AMRPWC 1990. An '89 would be a similar number.
boston 6902
I have found the numbers on my 1990 offshore sylvan, its got a 1988 3.0 omc engine anr the numbers are AMRGDP MODEL NUMBER, T01038034 SERIAL NUMBER.
I AM STILL LOOKING FOR THE 1988 3.0 OMC ORIGINAL OWNERS REPAIR MANUAL, EVINRUDE SAYS THEY WERE ALL LOST AFTER THE BUY OUT..?
